Error while deploying Tc11.2.1_ActiveWorkspace3.4_wntx64 on Tc11.4.0_patch_4_wntx64
I am getting error while deploying Active Work Space on Teamcenter.I am attaching the screenshots and installer syslog below.
Saura
Screenshot (17).pngTEMScreenshot (19).pngsqlplus
20 REPLIES 20
Re: Error while deploying Tc11.2.1_ActiveWorkspace3.4_wntx64 on Tc11.4.0_patch_4_wntx64
Good afternoon,
1) check in privileges:
grant сreate trigger to infodba identified by password
on your screenshot of this privilege is not visible.
2) Try to give this privilege in sqlplus by entering from under sysdba:
sqlplus / nolog
connect / as sysdba
grant create trigger to infodba identified by password;
Hi Arthur3,
Thanks for replying. I already have completed the steps that you have mentioned.Here is the screenshot of sqlplus showing the grant access:
Screenshot (20).pngSqlplus
Good afternoon, problem is that he can not grant privileges to/from yourself.  He must do this from another user.
Here's describe how to install database triggers for Oracle
https://docs.plm.automation.siemens.com/tdoc/aw/3.4/aw_html_collection#uid:xid1284832:index_Deployme...
They execute
grant Create trigger to infodba identified by the password;
from system user
Does your error occur before this step? (Install database triggers for Oracle).
Because your user infodba already has rights to create triggers, I suggest you try to find and comment this line in the script
D:\Kits\Tc11.4.0_patch_4_wntx64\wntx64\tc\install\sitecons\sitecons_install_triggers_oracle.sql
Something like:
Create trigger to infodba identified by password;
Hi Arthur3,
Thanks again.With reference to your question-"Does your error occur before this step? (Install database triggers for Oracle)" I would like to answer that yes,the error occured before that step. However, I followed all the steps that you mentioned but there is no line as "create trigger to infodba identified by password;" in the sitecon_install_triggers_oracle.sql script.I am attaching the script file below.
It looks like this line is not in this file, but somewhere in the installer's script. Check that you have a system user in Oracle, and it is active and you can login with system user. Try login in sqlplus with system user. In cmd where Oracle installed:
sqlplus system/password
I think that the installation script should run the same
grant Create trigger to infodba identified by password;
using a system user, but in your case it does not work.
I tried granting "Create trigger" privilege using SYSTEM but,it didn't work.
Could you please suggest any alternative to deploy AWS on TC11.4.0?
If I try to install AWS then the TEM goes into the recovery mode and again the same error is thrown.
Good afternoon, yes I think this will not help, because the script itself apparently tries to do this from under the infodba
you can return to the previous configuration, as described by RandyEllsworth in this thread:
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/tem-bat-stuck-in-rec...
You need to understand under what user it is trying to execute the script:
I think this should not be an infodba. You can try to install it again be carefully while doing each step.
Unfortunately I did not install the AWC myself, I only have the installation documentation.
Thanks Arthur3.I will follow the steps as suggested by RandyEllsworth in that particular thread which was suggested by you.
Thanks Arthur.
I followed the steps and was able to come out of recovery state.
