Error while opening NX part from teamcenter
Hi friends,
I am trying to open an NX model from my teamcenter. But I am getting some error.
Can anyone suggest a solution.
Should i change any configuration details for this.
Please refer the attachment
Ganesh
Re: Error while opening NX part from teamcenter
Esteemed Contributor
Under File => Utilities => License Options, you can select a bundle as the error implies.
Sorry my question is
When we open nx file, it will not ask for bundles.
But in my case it is asking for those bundles.,
Second can u see in that command window
logon failure.unknown username or bad password error..
so can u give any suggestion on this
Is your native NX session opened through a custom script?
Is this script also included in the one that starts NX from Teamcenter?
Does the Teamcenter user have a O/S user specified?
Is the correct O/S user specified?
Sorry unable to understand...
can u explain briefly
When you start NX without Teamcenter is this done through a custom batch script or similar?
Have you checked the NX log file for what the variable UGS_LICENSE_BUNDLE contains?
In Teamcenter in the organization perspective, check if the user has the correct value in the OS Name field.
