Excel Live : How to import Precise structure into Teamcenter
Hi, I have one question about the Excel Live.
I heard that Imprecise size structure can be imported into Teamcenter as a new data, using Excel Live.
Is it possible to import the precise structure into Teamcenter as a new data, using Excel Live?
Could you someone please tell me the answer for that?
If possible, could you tell me the reason for your answer?
Re: Excel Live : How to import Precise structure into Teamcenter
You cannot use Excel Live to import a precise structure.
Here's how you can accomplish your goal using a combination of tools:
1. Use ps_upload to create Items and Structure (imprecise).
2. Use Excel Live to update Item and Item Revision properties.
3. Use import_file to create and update (non-CAD) Datasets.
4. Use ps_traverse to set Structure to precise and quick release Item Revisions.
Evaluating:AW 3.2
Thank you so much.
I can understand it.
Builder
Builder
I have installed an excel integration to import data into tc8 using data and control files. But if items are in released status, it is saying that "The released version of object could not be modified".Import can be possible only if items are in "Unreleased status". Is there any way to achieve this,instead of "unreleasing" items?.
