ExcelTemplate Report
Hi All,
I want to create a report which gives Item revision in workflow and few propery values.
From the search result and I want to generate a report which give below values.
Item ID | Item Rev | Item type | workflow name | Workflow owner |Workflow created date|
But I could generate values as below
Item ID | Item Rev | Item type | workflow name|
But I want to traverse and get values from workflow.i.e., |Workflow owner |Workflow created date|
But couldn’t. And I am using excel template to export data.
Below is the procedure I am following to achieve it.
Please suggest how to traverse and get values or if there is another way please guide.
Thanks in advance.
