Exception: Received fatal alert: handshake_failure
we have got the following error while opening the TCSE 9 console.
Communication Error
URL: https://mydomain.com:443/tcr/controller/tcr_get_property_definitions
Has someone have an Idea how to solve it?
Re: Exception: Received fatal alert: handshake_failure
Builder
Builder
It may be caused by invalid SSL certificate. Try to open the TcSE url in your browser and check the SSL warning. If so, you may be able to export and install that SSL certificate in your "Trusted root" certs of your OS to ignore its validity.
