Existing Key-LOV Lists does not show the key-LOV I created
Hi All,
I am working on creating a part library using classification.  I've created 3 key-LOV lists, IDs -1, -2 and -3.
When I create an attribute and select the format, if I click the Key LOV tab, I can enter ID -1, -2 or -3 and select that list as the format for the attribute.  However, say I didn't know the ID of the LOV I want for that format.  From the attribute format window, if I click "Key LOV Panel" to show me the list of Existing Key-LOVs, the list is empty.  Even after I've entered ID -3 and I can see the preview of the list, when I go to the Existing Key-LOV list, none of my lists I created are there.
Any ideas on what I'm doing wrong here?
Thanks!
