Export an NX assembly from TC using rich client
Is that possible? Exporting all prt files generate assemblies with wrong links
Re: Export an NX assembly from TC using rich client
It is possible with PLMXML however the assembly will refer to parts by their Tc name (@DB\ItemID\RevID) and not their OS name (partxyz.prt). You should export from NX Manager to maintain the links.
Evaluating: AW 3.4
