Exporting NX data from Webclient
Hello All
Can we export NX data outside teamcenter through webclient. i undertnad we can export individual part as a Named ref export, but cn we export an whole Assembly outside and use in Native NX using Web client
Re: Exporting NX data from Webclient
Via webclient is a bit more difficult than RAC. Copy all the datasets to a folder to make it easier to select them all at once. Select datasets --> select Actions menu --> select Download File(s) --> choose a directory for downloads. Make sure you are only selecting datasets when attempting this method or it will give you a error "Only datasets should be selected".
Jamie Griffis
Mercury PLM Service
