Exporting assembly outside TC with adding db_part_name
Hi guys,
I'm exporting an assembly outside of Teamcenter.
When exporting, the PRT files only have the part ID's not names.
I wanted to add the DB_PART_NAME attribute as a suffix to all the parts when exporting but I couldn't succeed.
I added $DB_PART_NAME, <@DB_PART_NAME> etc, anything that came up to my mind.
None worked.
Any ideas?
Cem ALPAY
Cem
Re: Exporting assembly outside TC with adding db_part_name
did you try ${DB_PART_NAME}?
Best Regards
Harish
