FCC starts with RAC startup, but NOT using command prompt
When I start 4Tier RAC, FCC starts successfully.
But when I try the same using CMD, I get error "PID 3608 exited with status 0. FCC failed to start or restart".
No folders (FCCCache, etc.) are generated in %USERPROFILE% directory.
This does not happen on all clients. Any idea what's the reason for this ?
Re: FCC starts with RAC startup, but NOT using command prompt
It was simple: JRE_HOME needs to be set in environment variables.
