FSC Cache server OS upgrading to Windows server 2012 R2, is there any impact ob FSC services
We have one of the FSC Cache server on OS Windows server 2008, all other servers are Windows 2012 R2.
Planning to update Cache server from OS Windows server 2008 to Windows server 2012 R2.
only OS upgrade, Is there any impact on FSC cache?
Please suggest...
Re: FSC Cache server OS upgrading to Windows server 2012 R2, is there any impact ob FSC services
Likely, there will be no impact but to be safe you can delete the cache before upgrading the OS then populate it again after the upgrade.
Evaluating: AW 3.4
