FSC proxy error after Admin Data Import from different environment
I created DEV environment from fresh install. Once all features are installed, I did TEM --> Manage Admin Data --> Import Admin Data, from the package that I exported from PROD environment. Without realizing key preferences, I just overrided all preferences.
So obviously, I faced FSC error.
Later, I restored preferences by running preference_manager, restoring all site preferences back to original DEV Preference values. Also, deleted all temp folders. Still, am getting this error, while logging into Teamcenter 2 Tier Client.
 ERROR 41178 FSC proxy error: "-9009 NO_ROUTE_3{<SITE-ID>}{volume/logvolume}{<VOLUME-ID>}".
I tried generating meta cache again, as I might have deleted the folder. But no luck.
Any help to resolve is highly appreciated!
Anbu
Teamcenter Architect & PLM/CAD Administrator,
Teamcenter 11.4 | Active Workspace 3.4 | NX 12
Re: FSC proxy error after Admin Data Import from different environment
Solution:
After updating the following preferences using preference_manager, it works fine.
Fms_BootStrap_Urls
Default_Transient_server
Default_Transient_Volume_Id
Transient_Volume_Installation_Location
Transient_Volume_RootDir
Thanks to Rany & Ganesh
Anbu
