Re: FSC will not start
DEBUG - 2018/02/06-10:38:44,597 UTC - ######## - Notifying no-one, there are no waiting threads com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:1095) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
ERROR - 2018/02/06-10:38:44,598 UTC - ######## - Exception: ########.ext.####.com com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:142):com.teamcenter.fms.servercache.CommonsMLDLog.error(CommonsMLDLog.java:161) com.teamcenter.fms.servercache.proxy.CommonsFSCWholeFileIOImpl
WARN - 2018/02/06-10:38:44,598 UTC - ######## - FSC http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## [0] failed, assigning next FSC http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## [0]. com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:122)
ERROR - 2018/02/06-10:38:44,599 UTC - ######## - All servers failed with rollover errors. com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:142):com.teamcenter.fms.servercache.CommonsMLDLog.error(CommonsMLDLog.java:161) com.teamcenter.fms.servercache.proxy.CommonsFSCWholeFileIOImpl
DEBUG - 2018/02/06-10:38:44,660 UTC - ######## -
******************** BEGIN config OUTPUT *****************************
[com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:281):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,660 UTC - ######## - Error executing the command:config
All FMS servers are unavailable: please contact your system administrator.
FSC servers that were attempted: http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## ( Caused by: java.net.UnknownHostException: ########.ext.####.com ) [com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:284):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,661 UTC - ######## -
********************* END config OUTPUT ****************************
[com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:291):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:40:29,432 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:42:29,433 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
#########.ext.####.com     seems to be a problem
and if i run fscadmin.sh  something's not right:
####mjmca:/ # /apps/tceng/11.2/linux/fsc/fscadmin.sh -s http://#####MJMCA:4544  ./cachesummary
FSC_HOME or FMS_HOME must be set
#####mjmca:/ # /apps/tceng/11.2/linux/fsc/fscadmin.sh -s http:// g1ng02.#####.#####.com:4544 ./status
######jmca:/ #
how would the FSC_HOME environment variable normally be set?
and what should mine be set to?
Before you run fscadmin.sh you must set up the Teamcenter environment. Did you set $TC_ROOT and $TC_DATA, then source $TC_DATA/tc_profilevars?
erm no....
i just ran the install scripts for the FSC. i don't remember seeing anything in the FSC instructions about environment variables on the server
This is probably going to be an exercise in futility anyway if the service isn't running. I really recommend trying to start the service with elevated permissions, i.e., start it using sudo.
ok. 2 secs
