FSC will not start
Hello.
I have installed an FSC running on Suse Enterprise Linux server 12.
I followed the instructional PDF's from GTAC.
We are running Teamcenter 11.3.0.1
when i start the service on the FSC, the server connects ok and pulls down an FMS master configuration file.
the data folders for the cache start filling up. it all looks good.
after a couple of  minutes it errors, and the service fails to start.
the last entry in the startup log in /tmp says "Server Initialization successful, server is started."
I have tried to find other logs but there don't seem to be any.
the java process remains running though,  until I kill the PID.
Is there anything else I can do?
any more logs?
is there a way to run the service with more logging?
any help much appreciated.
thanks
phil
15 REPLIES 15
Re: FSC will not start
Obviously, the FSC service is able to talk to the FMS Master since an fmsmaster_*.xml is pulled. The most useful logs in this situation are the TC_ROOT\fsc\FSC_*.stdout and FSC_*.stderr logs. You can change the FSC_*.xml settings for debugging:
FSC_LogLevel="TRACE"
FSC_TraceLevel="ADMIN"
Evaluating: AW 3.4
ok will try now. thanks!
results:
i edited the xml and started the service.
btw, neither of the log files you mentioned are there in the tc root fsc folder. the startup log in /tmp seems to be all there is
it seems to have still defaulted to level "WARN"
the /tmp startup log says:
Unknown FSCDEFAULTS_LOGLEVEL log level: TRACE:com.teamcenter.fms.servercache.Log4JHelper.setLogLevel(Log4JHelper.java:399) com.teamcenter.fms.servercache.Log4JHelper
 - LogLevel is set to WARN by default.
the xml was originally set to
<!-- these are what we expect to be maintenance options -->
<property name="FSC_LogLevel" value="WARN" overridable="true" />
<property name="FSC_TraceLevel" value="2" overridable="true" />
<!-- segment cache sizing, read cache -->
oh dear :( ...
Too bad. Those values work for the FCC so I assumed they would work for the FSC equivalents. Set:
FSC_LogLevel="DEBUG"
Revert FSC_TraceLevel to its default value (2).
You might have a configuration issue since stdout and stderr files are not being written.
Evaluating: AW 3.4
You said: "after a couple of  minutes it errors, and the service fails to start"
What is the error displayed in the terminal window (assuming this is how you're starting it)?
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
hi
when i look at the startup log in /tmp, the service starts straight away.
the korn shell that i have launched it from gives the error after a couple of minutes.
ERROR: Failed to start fsc daemon.
Please refer to /tmp/FSC_90010MJMCA_startup.log for error messages.
the java process stays running until i kill it.
SO....
i left it running in debug mode, and eventually got some more stuff in the startup log.
it gets quite interesting at the bottom:
PART 1
2018/02/06-10:08:28,463 UTC MLD Log init: com.teamcenter.mld version V9000.1.0.20_20120806.00 (20121015)
log.properties found at /apps/tceng/11.2/linux/fsc/log.properties
OS name is Linux
JVM vendor is Oracle Corporation
Data model is 64
INFO - 2018/02/06-10:08:28,867 UTC - ######## - FMSServerCache starting...
INFO - 2018/02/06-10:08:28,868 UTC - ######## - FMSServerCache version: 11.3.0, build date: 20171013
INFO - 2018/02/06-10:08:28,868 UTC - ######## - FMSUtil version: 11.3.0, build date: 20171013
INFO - 2018/02/06-10:08:28,869 UTC - ######## - FSCJavaClientProxy version: 11.3.0, build date: 20171013
INFO - 2018/02/06-10:08:28,869 UTC - ######## - java.vm.version: 23.7-b01
INFO - 2018/02/06-10:08:28,869 UTC - ######## - java.vm.vendor: Oracle Corporation
INFO - 2018/02/06-10:08:28,869 UTC - ######## - java.vm.info: mixed mode
INFO - 2018/02/06-10:08:28,869 UTC - ######## - java.io.tmpdir: /tmp
INFO - 2018/02/06-10:08:28,869 UTC - ######## - java.library.path: ./lib
INFO - 2018/02/06-10:08:28,869 UTC - ######## - file.encoding: UTF-8
INFO - 2018/02/06-10:08:28,877 UTC - ######## - line.separator: LF
INFO - 2018/02/06-10:08:28,878 UTC - ######## - user.name: infodba
INFO - 2018/02/06-10:08:28,878 UTC - ######## - user.home: /home/infodba
INFO - 2018/02/06-10:08:28,878 UTC - ######## - user.dir: /apps/tceng/11.2/linux/fsc
INFO - 2018/02/06-10:08:29,161 UTC - ######## - ********************************************************************
INFO - 2018/02/06-10:08:29,161 UTC - ######## - Master FSC Path = ./fmsmaster_FSC_########.xml
INFO - 2018/02/06-10:08:29,161 UTC - ######## - Local FSCId = ########
INFO - 2018/02/06-10:08:29,162 UTC - ######## - Local enterpriseId = ##########
INFO - 2018/02/06-10:08:29,162 UTC - ######## - ********************************************************************
INFO - 2018/02/06-10:08:29,306 UTC - ######## - FSC Configuration master path: ./fmsmaster_FSC_########.xml
INFO - 2018/02/06-10:08:29,306 UTC - ######## - FSC Configuration local path: ./FSC_########.xml
INFO - 2018/02/06-10:08:29,306 UTC - ######## - FSC configuration is complete using a FMS master configuration file that matches the master served at http://g1ng02.niehl.####.com:4544/.
INFO - 2018/02/06-10:08:29,306 UTC - ######## - Located configuration for FSC: '########'
ERROR - 2018/02/06-10:08:29,314 UTC - ######## - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:423) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/06-10:08:29,315 UTC - ######## - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:430) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/06-10:08:29,316 UTC - ######## - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:437) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2018/02/06-10:08:29,316 UTC - ######## - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2018/02/06-10:08:29,316 UTC - ######## - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2018/02/06-10:08:29,351 UTC - ######## - Read Fast Cache initialized at: /data/FSCCache/########/read
INFO - 2018/02/06-10:08:29,352 UTC - ######## - Read Fast Cache parameter values: mfp=28672,ms=131072,hp=7812,me=999,memb=256
INFO - 2018/02/06-10:08:29,371 UTC - ######## - Write Fast Cache initialized at: /data/FSCCache/########/write
INFO - 2018/02/06-10:08:29,371 UTC - ######## - Write Fast Cache parameter values: mfp=28672,ms=15243,hp=7812,me=399,memb=256
INFO - 2018/02/06-10:08:29,374 UTC - ######## - Whole File Cache disabled at: /tmp/FSCCache
INFO - 2018/02/06-10:08:29,374 UTC - ######## - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
INFO - 2018/02/06-10:08:29,420 UTC - ######## - LogLevel set to DEBUG
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.BackupLocationManager
DEBUG - 2018/02/06-10:08:29,422 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
INFO - 2018/02/06-10:08:29,423 UTC - ######## - FileHandleCacheManager idleHandles: 0
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.io.WebRaidDownloaderCacheManager
INFO - 2018/02/06-10:08:29,426 UTC - ######## - WebRaidDownloaderCacheManager downloaders: 0, idleDownloaders: 0
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.cache.SingleRouteFastCacheHoleDownloader
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.cache.SingleRouteNoCacheHoleDownloader
2018-02-06 10:08:29.445:INFO::main: Logging initialized @1156ms
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.FSCHandlerList
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.OptionsHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.FMSWebHandlerRoot
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.downloadmanager.DownloadManagerWebHandlerHelper
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.LocalAdminHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.BootstrapHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.FCCConfigHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.AvailableFSCsHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.MasterConfigMD5Handler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.MasterConfigFileHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.SingleResourceHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.MSFrontPageHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.simplehandlers.UnhandledHandler
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.admincommands.AdminCommandBase
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.admincommands.MigrateCacheCommand
2018-02-06 10:08:29.570:INFO:oejs.Server:main: jetty-9.2.0.v20140526
2018-02-06 10:08:29.617:INFO:oejs.ServerConnector:main: Started ServerConnector@19996a2c{HTTP/1.1}{0.0.0.0:4544}
2018-02-06 10:08:29.617:INFO:oejs.Server:main: Started @1333ms
INFO - 2018/02/06-10:08:29,618 UTC - ######## - Server Initialization successful, server is started.
DEBUG - 2018/02/06-10:10:29,423 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:12:29,423 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:14:29,424 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:16:29,425 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
71,1 Top
DEBUG - 2018/02/06-10:18:29,425 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:20:29,426 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:22:29,427 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:24:29,427 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:26:29,428 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:28:29,428 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:30:29,429 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:32:29,430 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:34:29,430 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
TBC
startup log PART 2,
DEBUG - 2018/02/06-10:38:29,468 UTC - ######## - Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z] org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,480 UTC - ######## - enter GetMethod(String) org.apache.commons.httpclient.methods.GetMethod(GetMethod.java:90) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,481 UTC - ######## - HttpMethodBase.addRequestHeader(Header) org.apache.commons.httpclient.HttpMethodBase(HttpMethodBase.java:386) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@34adb165, name=log4j:logger=com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager
DEBUG - 2018/02/06-10:38:29,520 UTC - ######## - Set parameter http.connection-manager.max-per-host = {HostConfiguration[]=2147483647} org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,521 UTC - ######## - Set parameter http.connection-manager.max-total = 2147483647 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,521 UTC - ######## - Set parameter http.connection.stalecheck = true org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,522 UTC - ######## - Set parameter http.socket.sendbuffer = 132096 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,523 UTC - ######## - Set parameter http.socket.receivebuffer = 132096 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,525 UTC - ######## - Java version: 1.7.0_17 org.apache.commons.httpclient.HttpClient(HttpClient.java:72) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,526 UTC - ######## - Java vendor: Oracle Corporation org.apache.commons.httpclient.HttpClient(HttpClient.java:73) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,526 UTC - ######## - Java class path: jar/fmsservercache.jar:jar/fmsutil.jar:jar/fscjavaclientproxy.jar:third_party/commons-collections/3.2.2/commons-collections-3.2.2.jar:third_party/commons-logging/commons-logging-1.0.4/commons-logging.jar:third_party/commons-httpclient/commons-httpclient-3.1/commons-httpclient-3.1.jar:third_party/commons-codec/commons-codec-1.3/commons-codec.jar:third_party/javamail/1.3/mail.jar:third_party/mld/tc9.1.0.20120806/plmJMXmonitor.jar:third_party/mld/tc9.1.0.20120806/log4j-1.2.13.jar:third_party/mld/tc9.1.0.20120806/jmxtools.jar:third_party/mld/tc9.1.0.20120806/jmxri.jar:third_party/mld/tc9.1.0.20120806/logwriter.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/onion-common.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/onion-wantransport-tools.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/onion-webraid.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/onion-webraidutil-tools.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/onion-webraidutil.jar:third_party/OnionNetworks/webraid-2.6.8_01/lib/jdom.jar:third_party/jetty/9.2.0/jetty-server-9.2.0.v20140526.jar:third_party/jetty/9.2.0/jetty-util-9.2.0.v20140526.jar:third_party/jetty/9.2.0/jetty-http-9.2.0.v20140526.jar:third_party/jetty/9.2.0/jetty-io-9.2.0.v20140526.jar:third_party/jetty/9.2.0/servlet-api-3.1.jar:third_party/TcSS/TcSS11.3.20170303/jars/.:third_party/TcSS/TcSS11.3.20170303/jars/teamcenter_sso_common.jar:third_party/TcSS/TcSS11.3.20170303/jars/teamcenter_sso_webtoolkit.jar:third_party/TcSS/TcSS11.3.20170303/jars/teamcenter_sso_applib.jar:third_party/TcSS/TcSS11.3.20170303/jars/teamcenter_sso_ldapcustom.jar:third_party/TcSS/TcSS11.3.20170303/jars/log4j-api-2.7.jar:third_party/TcSS/TcSS11.3.20170303/jars/log4j-core-2.7.jar:third_party/TcSS/TcSS11.3.20170303/jars/ws-commons-util-1.0.2.jar:third_party/TcSS/TcSS11.3.20170303/jars/xmlrpc-client-3.1.3.jar:third_party/TcSS/TcSS11.3.20170303/jars/xmlrpc-common-3.1.3.jar:third_party/TcSS/TcSS11.3.20170303/jars/xmlrpc-server-3.1.3.jar org.apache.commons.httpclient.HttpClient(HttpClient.java:74) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,527 UTC - ######## - Operating system name: Linux org.apache.commons.httpclient.HttpClient(HttpClient.java:75) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,528 UTC - ######## - Operating system architecture: amd64 org.apache.commons.httpclient.HttpClient(HttpClient.java:76) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,540 UTC - ######## - Operating system version: 3.12.28-4-default org.apache.commons.httpclient.HttpClient(HttpClient.java:77) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,545 UTC - ######## - SUN 1.7: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,546 UTC - ######## - SunRsaSign 1.7: Sun RSA signature provider org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,546 UTC - ######## - SunEC 1.7: Sun Elliptic Curve provider (EC, ECDSA, ECDH) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,547 UTC - ######## - SunJSSE 1.7: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,548 UTC - ######## - SunJCE 1.7: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,549 UTC - ######## - SunJGSS 1.7: Sun (Kerberos v5, SPNEGO) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,549 UTC - ######## - SunSASL 1.7: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,550 UTC - ######## - XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory) org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,551 UTC - ######## - SunPCSC 1.7: Sun PC/SC provider org.apache.commons.httpclient.HttpClient(HttpClient.java:82) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,551 UTC - ######## - Set parameter http.socket.timeout = 0 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,552 UTC - ######## - Set parameter http.authentication.credential-provider = com.teamcenter.fms.util.authentication.FMSHttpState$SSOCredentialsProvider@51d7bd99 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,553 UTC - ######## - Set parameter http.connection-manager.timeout = 90000 org.apache.commons.httpclient.params.DefaultHttpParams(DefaultHttpParams.java:151) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,554 UTC - ######## - HttpMethodBase.addRequestHeader(Header) org.apache.commons.httpclient.HttpMethodBase(HttpMethodBase.java:386) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,555 UTC - ######## - enter HttpClient.executeMethod(HttpMethod) org.apache.commons.httpclient.HttpClient(HttpClient.java:321) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,556 UTC - ######## - enter HttpClient.executeMethod(HostConfiguration,HttpMethod,HttpState) org.apache.commons.httpclient.HttpClient(HttpClient.java:374) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,561 UTC - ######## - enter HttpConnectionManager.getConnectionWithTimeout(HostConfiguration, long) com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager(MultiThreadedHttpConnectionManager.java:446) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,562 UTC - ######## - HttpConnectionManager.getConnection: config = HostConfiguration[host=http://########.ext.####.com:4544], timeout = 90000 com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager(MultiThreadedHttpConnectionManager.java:455) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,563 UTC - ######## - enter HttpConnectionManager.ConnectionPool.getHostPool(HostConfiguration) com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:919) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,564 UTC - ######## - enter HttpConnectionManager.ConnectionPool.getHostPool(HostConfiguration) com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:919) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,565 UTC - ######## - Allocating new connection, hostConfig=HostConfiguration[host=http://########.ext.####.com:4544] com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:871) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,569 UTC - ######## - Attempt number 1 to process request org.apache.commons.httpclient.HttpMethodDirector(HttpMethodDirector.java:379) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,569 UTC - ######## - enter HttpConnection.open() org.apache.commons.httpclient.HttpConnection(HttpConnection.java:685) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:29,570 UTC - ######## - Open connection to ########.ext.####.com:4544 org.apache.commons.httpclient.HttpConnection(HttpConnection.java:692) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,588 UTC - ######## - enter HttpConnection.closeSockedAndStreams() org.apache.commons.httpclient.HttpConnection(HttpConnection.java:1215) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,589 UTC - ######## - Closing the connection. org.apache.commons.httpclient.HttpMethodDirector(HttpMethodDirector.java:404) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,590 UTC - ######## - enter HttpConnection.close() org.apache.commons.httpclient.HttpConnection(HttpConnection.java:1148) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,591 UTC - ######## - enter HttpConnection.closeSockedAndStreams() org.apache.commons.httpclient.HttpConnection(HttpConnection.java:1215) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,591 UTC - ######## - Method retry handler returned false. Automatic recovery will not be attempted org.apache.commons.httpclient.HttpMethodDirector(HttpMethodDirector.java:434) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,592 UTC - ######## - enter HttpConnection.releaseConnection() org.apache.commons.httpclient.HttpConnection(HttpConnection.java:1174) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,593 UTC - ######## - Releasing connection back to connection manager. org.apache.commons.httpclient.HttpConnection(HttpConnection.java:1178) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,594 UTC - ######## - enter HttpConnectionManager.releaseConnection(HttpConnection) com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager(MultiThreadedHttpConnectionManager.java:703) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,594 UTC - ######## - Freeing connection, hostConfig=HostConfiguration[host=http://########.ext.####.com:4544] com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:1115) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,595 UTC - ######## - enter HttpConnectionManager.ConnectionPool.getHostPool(HostConfiguration) com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:919) [com.teamcenter.fms.servercache.CommonsMLDLog.trace(CommonsMLDLog.java:127):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,596 UTC - ######## - Adding connection at: 1517913524595 org.apache.commons.httpclient.util.IdleConnectionHandler(IdleConnectionHandler.java:76) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,597 UTC - ######## - Notifying no-one, there are no waiting threads com.teamcenter.fms.servercache.proxy.MultiThreadedHttpConnectionManager$ConnectionPool(MultiThreadedHttpConnectionManager.java:1095) [com.teamcenter.fms.servercache.CommonsMLDLog.debug(CommonsMLDLog.java:153):Thread[FSCBackgroundThreadPool_1,4,main]]
ERROR - 2018/02/06-10:38:44,598 UTC - ######## - Exception: ########.ext.####.com com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:142):com.teamcenter.fms.servercache.CommonsMLDLog.error(CommonsMLDLog.java:161) com.teamcenter.fms.servercache.proxy.CommonsFSCWholeFileIOImpl
WARN - 2018/02/06-10:38:44,598 UTC - ######## - FSC http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## [0] failed, assigning next FSC http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## [0]. com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:122)
ERROR - 2018/02/06-10:38:44,599 UTC - ######## - All servers failed with rollover errors. com.teamcenter.fms.servercache.proxy.common.ProxyLogWrapper(ProxyLogWrapper.java:142):com.teamcenter.fms.servercache.CommonsMLDLog.error(CommonsMLDLog.java:161) com.teamcenter.fms.servercache.proxy.CommonsFSCWholeFileIOImpl
DEBUG - 2018/02/06-10:38:44,660 UTC - ######## -
******************** BEGIN config OUTPUT *****************************
[com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:281):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,660 UTC - ######## - Error executing the command:config
All FMS servers are unavailable: please contact your system administrator.
FSC servers that were attempted: http://########.ext.####.com:4544/tc/fms/########/Suppliers/######## ( Caused by: java.net.UnknownHostException: ########.ext.####.com ) [com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:284):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:38:44,661 UTC - ######## -
********************* END config OUTPUT ****************************
[com.teamcenter.fms.servercache.monitoring.FSCHealthDiagnosticsWrapper.dumpOutputToLogger(FSCHealthDiagnosticsWrapper.java:291):Thread[FSCBackgroundThreadPool_1,4,main]]
DEBUG - 2018/02/06-10:40:29,432 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
DEBUG - 2018/02/06-10:42:29,433 UTC - ######## - Quarantine list checked, removed 0 links. [com.teamcenter.fms.servercache.routing.LinkQuarantineList.periodic(LinkQuarantineList.java:190):Thread[LinkQuarantineListPeriodic-0,5,main]]
"all servers failed with rollover errors"
these lines indicate that you're starting FSC with a user that is not root:
Have you tried starting the FSC daemon using root permissions? For example (I'm guessing on the name of the script; substitute the real one):
            sudo /apps/tceng/11.2/linux/fsc/rc.ugs.FSC_90010MJMCA_infodba
