Filter array of untyped references in tcxml_export
I'm trying to filter untyped reference by any sign in tcxml_export. For example:
I have property [Untyped reference] as named as "fds4_documents". This property contains different object.
 I write property set: [ItemRevision] [FDS4_Doc] [fds4_documents] [DO]:
I want to export objects only with atribute fds4_doc_type  "Memorandum". I can write Filter Rule. In *.xml file I have needful objects, but property  "fds4_documents" will have links to not available objects.
<ItemRevision.............. fds4_documents="#id4 #id5 #id6 #id7".............>
 Is it possible in TCXML?
