Find the Workflow codefully
Dear Listers,
I am writing an custom rule handler and would like to assign the custom rule handler to the start of the workflow.
Would like to understand how can I check the name of the workflow codefully.
Here is what I am checking
ITK(retcode,EPM_ask_root_task(message.task,&tRootTask));
if(tRootTask != NULLTAG)
ITK(retcode,EPM_ask_attachments(tRootTask, EPM_target_attachment, &iTargetAttchmnt, &tAttchItemTag));
Before getting into the IF task I would like to find the name of the workflow.
Will it be possible with the Handler EPM_ask_name(RootTask, &root_name)?
Vilas
3 REPLIES 3
Re: Find the Workflow codefully
Good afternoon,
I think that you are on the right path and you should get a name, you need to try to do this on a test case.
The test went fine it worked. EPM_ask_name gives the name of the workflow to which the item is attached
Vilas
Good afternoon, I'm glad that you made it :)
