Form display order different between double-click and view/edit property
Hi guys,
I had this problem that somehow,,
when DOUBLE CLICK FORMS,  all are displayed in different order as we put in the xml rendering stylesheet, they are in alphabetical order.
when view/edit property of a form, they are displayed the same as we defined in xml stylesheet...
Re: Form display order different between double-click and view/edit property
You have several stylsheets for your form:
- Summary
- Property
- Form
When you double click the form or display it in the viewer the "form" stylesheet will be used.
When you view or edit properties the "property" stylesheet will be used.
In the summary tab the "summary" stylsheet will be used.
Maybe you have just customized one of them.
Or if you use custom forms maybe the default form stylsheet will be used for one of the above mentioned cases.
Oh...I have never realized there is another Form stylesheet...Thanks Daniel! It works as intended right now.
