FormLOVButton does't show selected LOV on windows 8 machines
Builder
Builder
When we select an LOV from FormLOVButton,it's starting disappearing on windows 8 machines.
An engineer not able to proceed further.I have tried everything like changing the resolution,changing the theme but still facing the same problem.Any fix for this kind of issues..
Re: FormLOVButton does't show selected LOV on windows 8 machines
I think GTAC is the right point of contact for such issues.
Builder
Builder
Discussed with them also.But no solution so far as.
Builder
Builder
Hi all,
any updates?
if if you are on teamcenter8.3, then verify if formlovbutton is deprecated.
i think it is deprecated.
try using its alternate representation and see if you still get the same behaviour.
Best Regards
Harish
Builder
Builder
Yes. FormLOVButton is Deprecated. But, after replacing this with new api PropertyLOVButton (com.teamcenter.rac.stylesheet.PropertyLOVButton) also, it didn't work. Looking for other possibilities.
On second thoughts:
Did you get the same behavior if you attached LOV at property level through BMIDE?
Consider that PropertyLOVButton is deprecated starting TC10.1.6 !
Best Regards
Harish
Builder
Builder
Hi
After replacing new api also, I am facing the same issue.
