cancel
Get parent ID using Report Builder
Hi
Using Report Builder
For a given child , Pl help on how to get its immediate Parent Item ID.
I am looking for the Syntax to extract the Parent Item ID in Report Builder XSL
is there any document which helps for xsl compilation as per the requirement
Vamsi Krishna
