Getting a new ask to save window, in an PostAction at IMAN_save operation
Hi, all,
I am new in the code world of Teamcenter, I am doing a PostAction for an object, I need to update some attributes, but at the end show me a popup window point to me that there are changes in the panel and I need to save it, the problem is my code is in IMAN_save operation and is intended to be used in the creation process, right now I have it for any save operation, so if I save the panel runs again the PostAction, this happened when I use AOM_UIF_set_value, because AOM_set_value_string doesn't do the change. I have AOM_save and AOM_unlock in the code.
Thanks for any insight.
