Getting drawing component name as attribute in Teamcenter
Hi guys,
I'm trying to create a Drawing Template.
This will be used as a Master Drawing template.
I need it's part_name and ID and the drawing's revision in it, which is not a problem.
I've added a component to get the drawings from.
I can get drawing parts name/ID and revision automatically but can't get the main part's (in the picture it is 000364/A01) name/ID and revision.
Where can I get to those attributes?
Cem
