Getting error while deploying changes made BMIDE on testing server
1. Deleted property renderer object in bmide. 2. Since then getting following error while deploying the changes to testing server:- Deploy Data Model failed.
Re: Getting error while deploying changes made BMIDE on testing server
Post the deploy logs the error message cites.
Found this line in the second deploy log:
Delete | TcTypeConstantAttach| CreateInput:A5_WorkshopPart    | -1 | The Type Constant Attachment "" cannot be deleted, because the Operation Input Type "" exists in the database. Please delete the Operation Input Type first and try again.
Can you please guide me in which file exactly I should make the changes that you have suggested?
I have just started exploring BMIDE, hence don't know how to make changes that you have suggested.
N don't want to make matter worse by making changes in wrong files.
Thans
I only pointed out the error described in the log file. In order to help you we'd need a lot more information about what you're trying to do.
