Getting error while deploying changes made BMIDE on testing server
1. Deleted property renderer object in bmide. 2. Since then getting following error while deploying the changes to testing server:- Deploy Data Model failed.
Re: Getting error while deploying changes made BMIDE on testing server
Good afternoon, you should check the logs in the screenshots for more information about the error.
