Grayed Attribute
It's possible to gray the "Type " attribute:
For exemple impossible to modify RTDI value.
Re: Grayed Attribute
The field is mandatory which is why it shows up in the create wizard. You'll need to set a default value before making the field read-only in BMIDE else you won't be able to create Items (AEDE_Commercial).
Evaluating: AW 3.4
