Hard deleting of a dataset
Hi
I defined a new dataset and a tool for that on BMIDE and deploy it with TEM, but unfortunatly it is not working.
I created some datasets from that type and now I want to delete them. I deleted all of them but once, with this error: You cannot delete the master copy of a replicated object.
I dont now how I should find replicated objects to this dataset.
It will be apreciated if you help me to fix this problem. I have access to database and I can hard delete that dataset if it is needed.
Thank you.
Re: Hard deleting of a dataset
