Has anyone customized Smart Codes in TC RapidStart?
Looking for information on editing the OOTB Smart Codes.  Currently using TC v10 and NX v8.5. Thanks in advance!
6 REPLIES 6
Re: Has anyone customized Smart Codes in TC RapidStart?
Actualy I'm also into this editing the Smart Codes thing and wondering how to do it.
I guess there are not much Rapid Starters around :)
Cem
Smart Codes have been replace with ID Generation Rules in 11.2. I've used the new format. What version are you on now? Did you get Smart Codes working?
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
I also used new format for TC 11.2..
It works as my customer's needs.
Saygılarımla,
Cem ALPAY, Yönetici
ÜÇGEN YAZILIM LTD. ŞTİ.
TEL: 0216 550 52 06
[cid:image001.jpg@01D3587E.E2EEF0F0]
Thanks Jamie,
We recently upgraded to TC11  NX12.  I'll have to look at ID Generation Rules.
Sounds promising.  Any advise?
True...  I hear you...
Looks like ID Generation rules are the replaced to Smart codes.  Have you tried yet?
Any advice?  Thanks
I tried ID Generator and I hate it. You cannot use it from any of the CAD (SE, SW, Catia) but I'm not sure about NX12 so maybe that one works now? You also cannot Save As to a new number. We replaced it with custom code. It's not ready in my opinion. I had to create 1450 conditions and concatenation rules in the ID Generator to make mine work as requested. Not an fun task! Let me know if you try it and like it or not. I'm interested in why anyone would want to use it if you can't Save As.
Jamie
