Have EWI only "step" through operations, omitting process nodes
I was wondering if its possible to have EWI omit showing work instructions for process nodes, and jump right to its child operation instead? As I have it now, I have to click through "empty" pages of work instructions every time I click "next step" and the next step happens to be a process node instead of an operation with attached work instructions.
Thank you.
Re: Have EWI only "step" through operations, omitting process nodes
Siemens Creator
Hello There,
What version of Tc, AWC and EWI are you using? I happened to stumble into this problem and still trying to workout a solution for it. Did you manage to get it working?
Try the property EWI_HiddenComponents, that should be empty.
Luis Valencia
