Have different pattern for Item_ID depending of groups
Anyone know if it is possible to have different naming rule for the Item_ID (for the same Item type) depending of the group.
Exemple:
Group A - Create Item - Pattern = nnnnnnn
Group B - Create Item - Pattern = "AV-"nnn
Thank you in advance for your help.
7 REPLIES 7
Re: Have different pattern for Item_ID depending of groups
Addition: if you have access to Solution Center
http://solutions.industrysoftware.automation.siemens.com/
then look there document with ID: josiasj_061312
also look good information from plmdojo site:
http://plmdojo.com/bmide/teamcenter-conditions/#.W5t6--gzZPY
Yes, this can be done with conditions like @ArthurRM mentioned. I've done it several times and it works well. Go through the links in Authur's post. If you have questions after that, I'll be glad to help you.
Jamie
Jamie Griffis | PLM Solution Architect | Engineering USA
we did this by defining conditions with custom input parameters.
You could create two naming rules and two conditions e.g. isGroupA and isGroupB with
Signiture: UserSession u
Expression: u.group_name = "Group Name"
Then use the corresponding condition when you attach the property in the naming rule.
I hope this could help you.
best regards
Review this post as well: https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Restrict-naming-rule...
Hello @Jamie_Griffis, @Volker_A, @ArthurRM,
Thank you for your help, it's exatly what I wanted.
I allow myself to add some dificulty: do you know if it's possile on the save as recover the number of the first Item to the new Item ?
Exemple:
User group A --> Creat Item ---> "CAD-"nnnnnn --> CAD-000001
User group B --> Save as Item ---> "SAV-"nnnnnn --> SAV-000001
I recover the 000001 since the fisrt Item to the new Item.
That is posible ?
Best regards,
Each counter works independently and they will start where you set them.
Jamie
