Help with handler EPM-notify-report
I create a worflow who allows to send emails.
I receive the mail but i have an error at level of handler EPM-nofify-report if i want approve (see screen copy)
Thank you for your help
Re: Help with handler EPM-notify-report
What arguments are you using with EPM-notify-report? You'll need to select one of the EPM-notify-report handlers in the list (Workflow.png) in order to show the arguments.
I'm guessing that you're missing "-report=level" or "-report=progress" which are recommended for the Complete action where you have EPM-notify-report specified. You have two of them on Complete?
Thanks for your answer.
There's the argument i've used  (See screen copy)
The -report switch is mandatory. -report={review|rejection|progress|level}
progress or level are acceptable for the Complete task.
https://docs.plm.automation.siemens.com/tdoc/tc/11.2.3/help/#uid:CR-notify
It works. Thanks very much.
