Hide Queries based on Groups and Roles
Hi guys,
In our environment we have a lot of queries created in Query Builder.
Some of them are not intented to be used by a 'normal user'. These are used in Workflows, Server Extensions, etc. Another part of them are relevant just for a given Group and/or Role.
Is there someone who knows a way, how these queries could be to hidden/shown based on the users's Group / Role?
Br,
ZsCsaba
Software Engineer
Re: Hide Queries based on Groups and Roles
For technical queries (e.g. for worflows), you can name it with suffix "__" (double underscore), these queries will be hidden for all except dba role.
I knew this "double underscore" thing, but with a prefix. :) And that part is working fine.
My biggest issue is with the queries, that should be visible only for a certain Group / Role.
Software Engineer
My mistake, yes I wanted to say prefix.
The only possibility is to use ACL to filter, but take care about the collateral damage (TC is very sensible when you want to add acl rules on standard objects).
You're right, I have managed to do it.
Here are the steps that needs to be done:
Has Class ( POM_application_object) -> Working (this one is OOTB)
   - Has Class( ImanQuery ) -> < General ACL, to add a new layer of indirection >
      - Has Attribute( ImanQuery:query_name=<your_query_name> ) -> New ACL
In this new ACL you can specify the groups and/or roles that should or shouldn't  see the <your_query_name> query.
Br,
ZsCsaba
Software Engineer
Hello: @ZsCsaba
I met the same needs as you, but I am also so configured, did not take effect!
Here's my configuration.
help me,Please!  think you.
Hi tranyao,
Remove the "<“ and “>" characters.
If it still doesn't work, just let me know.
Br,
Csaba
