Hosting active workspace in Solid Edge 9
Hello All,
               I was trying to host active workspace in Solid Edge 9.
To host active workspace in ST9 I created a preference "ActiveWorkspaceHosting.SEEC" and set their values to the URL of the Active Workspace installation. But still I am unable launch active workspace from ST9. I am not getting the docking window of active work space in ST9.
Please someone help me if i have missed out any step.
Thanks and Regards
M.Manoj Krishna
Re: Hosting active workspace in Solid Edge 9
Hi @krish31,
You may be sorted already, but I came across this post when trying the same thing. I think the preference you should be using is "ActiveWorkspaceHosting.SEEC.URL" with value as the URL.
Hi Alex,
Actually you have to give that active workspace URL in the Define Teamcenter Database of Solid Edge also.
Then you can host active workspace in ST9.
Thanks and Regards
Krish
Hello Alex,
Set preference name: ActiveWorkspaceHosting.SEEC.URL to use awc in ST9
you can see this page
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Change-Active-Worksp...
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
