How can I attach my JAR as PLM connector to transfer data from team center to my MES system?
Dear all,
As per my requirement, there is one MES system which I am using since long time. Now I want to transfer data from team center to this MES system within click. For this I need to use JAR file which will work as PLM connector between these two systems as his can convert all data from team center to MES required format.
But here the question is how can I attach this JAR file to team center 10/11?
Is there any way for it?
Re: How can I attach my JAR as PLM connector to transfer data from team center to my MES system?
Teamcenter provides SOA APIs (Java) to connect with third party softwares. You can read/write data in Teamcenter using various services provided there. I hope this info helps.
Thanks.
Can you please elaborate more for me so that i can have better idea to implement it using SOA API ? As how can i use it ? Is there any ready made document in terms of usage guidelines for it ?
