How can I delay Workflow ?
Hallo Everyone,
how can I delay Workflow until the JT is generated?
What I want is: E-Flag should be executed, after the dispatcher has generated JT.
Thank you for help.
9 REPLIES 9
Re: How can I delay Workflow ?
Simplest method would be to run a query, or have a validate task check that the JT is present.  User would just have to keep completing a task.
Rich
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Hi
can you show it to me with an example?
Rich
Richard Bennett
PLM Consultant
I´m checking already with this handler.
But anyway i want to add in WF a delay/time-out, because JT Dispatcher sometimes needs more time.
Is there any solutions?
Thank you for help.
Try this solution:
Create a task with the EPM-run-external-command Handler.
Argument -lov
Value [Your BMIDE LOV Name]
BMIDE LOV:
INPUT~Application=${c:\plm\tc11\WKFL-PAUSE.CMD}
PAUSE.CMD:
@ECHO off
PING -n {seconds} 127.0.0.1 >NUL 2>&1
REM or use the SLEEP command like
REM SLEEP {seconds}
Michael
Teamcenter UA | NX CAD
what should I write in Do Task and in Or?
Who you ask?
Michael
That´s was question for ProspectPLM.
You dont need any handlers on DO or OR tasks.  Just write some instructions for the user on the DO task along the lines of:
"The JT hasnt been created yet.  Please complete this task in a few minutes.  When the JT has been created the workflow will allow you to proceed to the next task"
Rich
Richard Bennett
PLM Consultant
