How can I do to display the property in the viewer , which was using by Intelligent part numbering?
Dear all
        I have a problem with Intelligent part number.
        At present, I have used the intelligent part number for an customer object base on Design , and it's work ;
        But now , I want to make those properies which was using by intelligent part number, can be display in the viewer;
        Like the create wizard , after create a custom style sheet for your custom business object based on the ItemCreate.xml style sheet, I can see those properties when I created a object.
1.png2.png         How can I do to display the property in the viewer?
