How can I validate property value?
Siemens Creator
Hello gurus
I have the following situation... I've two properties, one at the Item and other at Item revision, but I need to validate these property value, for example:
If Item property = 1, Revision Property must be = A or B
If Item Property = 2, Revision Property must be = C or D
I tried to create conditions in BMIDE and use with LOVs but it didn't work, conditions in LOV only use user session.
Its possible make these configuration?
