How change a label on structure manager
Hi everybody,
I search on TC 8.3 for changing the name of a column on Structure Manager! Do you know who I can?
See example on Attachments.
Thank you
PLM Technical IT
3 REPLIES 3
Re: How change a label on structure manager
If you display the internal name and not the translated one, you get the object that needs the translation to be changed in BMIDE.
Employees of the customers, together we are strong ;)
Ok thank you! I will search on BMIde.
Do you know exactly who is on Bmide?
PLM Technical IT
Hi everybody,
do you know where I can change the translation? I found nothing where I search on BMIde?
Thank you
PLM Technical IT
