How do I prevent users from approving own work
I need to prevent users who are in the design group and checking groups from being able to approve their own work. The user initiates the workflow which goes for check by anyone in the checking group. They can currently approve their own work.
Thanks.
8 REPLIES 8
Re: How do I prevent users from approving own work
You don't say what Teamcenter version you're using so I'll assume the latest and answer: TCRS-check-approver. The handler allows you to compare two sets of users against each other so that they are not in both sets. In other words, they cannot approve their own work.
Evaluating: AW 3.4
Sorry were currently running 10.1.3. I had found TCRS-check-approver but it doesn't work. I send items to the Check Group/Role and am trying to stop the workflow initiator from being able to approve their own work. It does error saying that the workflow fails but rather than stopping it continues on after the error stating TCRS-check-approver.
Siemens Genius Siemens Genius
Siemens Genius
Try EPM-disallow-reviewers rule handler:
-assignee   user:$PROCESS_OWNER
This might help!
Been speaking to Siemens, in 10.1.3 it is broken. Suposedly fixed in 10.1.4.
we have TC 10.1.4.
Where can I find this handler EPM-disallow-reviewers? Is it in this version of TC or in a newer version?
I have 10.1.6 and can't find it either.
Would be really useful to prevent people approving the own work. Which we currently enforce through process.
Hi Rill,
have you tried it with TCRS-check-approver? My problem is, that I don't know exactly where do I have to enter this handler. I mean in which phase/task of the workflow. Than it should return back to select other reviewer/examiner.
I tried with the following arguments:
-a_task | $USER
-b_task | $USER
Any experience or advice?
I'll give it a go.
