How do i change the look up order for the dataset in the embedded viewer?
How do i change the look up order for the dataset in the embedded viewer when I click on itemrevision?
dataset's relation is all IMAN_specification.
[Teamcenter version :: 11.3]
Thanks by advance for your help.
Re: How do i change the look up order for the dataset in the embedded viewer?
Its specified in a plugin, com.teamcenter.rac.common.tcviewer\tcviewer.properties
DatasetViewer.RELATIONSEARCHORDER is the order of DS chosen.
ImagePreview.VIEWSEARCHORDER is the order within a DS chosen.
https://docs.plm.automation.siemens.com/tdoc/tc/11.3/help/#uid:xid301455
Evaluating: AW 3.4
