How to Display relation object
Hi, I tried to display the relation business object under custom Item(not Item Revision).
The following is the my setting.
In the option, I selected specific group in the organization box.
Category General
Current value : IMAN_reference
After closing teamcenter and clear cash data in my local machine, the relation business object was not diplayed under Custom Item.
Could you help me to solve this question?
Re: How to Display relation object
As per my understanding, you want have "Iman_reference" relation on your custom object type, to add secondary objects by this relation.
It possible by Teamcenter preferences Edit--> Options, (we can select Item type & Item Revision type and add the new relation)
This preference will display the secondary related object:
Value: IMAN_reference
If you wish to display a pseudo folder as well, then include an additional preference:
Harish
