How to View all the comments for the object in a workflow ?
All,
How to view, all the comments keyed in by the users, when an object goes through a workflow ?
In our setup, we have an Custom Item Revision which goes through the workflow, and our workflow have the following tasks,
1) Acknowledge Task,
2) Do Task - Notifiy Task (incase the task cannot be performed)
3) Review Task
4) Decide Task
5) Assign Status.
Do we need to generate a report ? e-learning advantage mentions to run the following report
"Audit - Workflow Signoff Report" and i am unable to find this in our installation. Any pointers would be of a great help.
Cheers !
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
5 REPLIES 5
Re: How to View all the comments for the object in a workflow ?
In Teamcenter 10, on the Summary tab, you should be able to find a tab called "Audit Logs".
There you can see the complete Workflow Log with all comments.
Best Regards
Tobbe
Could you please post a picture ? i cannot find it in our environment. Also forgot to mention that we have customised the Style Sheet for the Summary tab.
Would be a great help.
Cheers.
Teamcenter 10.1.7
Here is a picture of how our Summary tabs looks like:
I guess that if you search for "tc_xrt_AuditLogs" in the Teamcenter Product Documentation, you might get some guidance of how to add it to the stylesheet.
Unfortunately none of the TC 10 documenation sites work for me at the moment... So I can't confirm if it will help/guide you or not...
Best Regards
Tobbe
Thanks Tobbe,
Had to enable a preference "TC_audit_manager = 3" to see the Audit Logs tab in the Summary Tab.
Cheers.
Teamcenter 10.1.7
Tools -> Reports -> Worflow SignOff Reports
will also give audit details, with all Comments in a htmlp report.
PLM Consultant
