How to apply custom preference to user?
-How to controle the "Available Columns" list in BOM line in Stucture Manager Module?
-How to apply a custom preference to a particular user?
Thanks & Regards
Shailesh Haridas
Re: How to apply custom preference to user?
- Right click on any column name and you get options to insert/remove column. I hope this is what you are looking for.
- Create new preference with "Protection Scope=User".
Then in Edit-Options dialog, select "Organisation" (at bottom of dialog).
Select the preference. Then select the inteded user from organisation.
On top left of the dialog option "Create a new preference instance" is now active (was greyed out till now)
Now you will have a copy of preference with "Location=User"
Thank you for reply,
But for 1st point, I want to show only required column list in "Available Columns" Chooser or I want to restict the user from inserting/removing the column.
I have attached the screen shot of 1st issue.
Please find attachement.
Thanks and Regards
Shailesh Haridas
sorry I've no idea how to do that.
