How to attach the dataset in the target folders to the notifcation emails
Hello Experts,
I am creating a workflow where after release I need to send a notification to a user with the dataset (an excel file) in the target folder of the workflow attached to the notification email.
I have tried to use the EPM-Notify handler with argument "-attachment" and value as "target"
This yields no results.
Does anyone have a solution for this issue?
Thanks in advance.
13 REPLIES 13
Re: How to attach the dataset in the target folders to the notifcation emails
Hi Rushi,
from the documentation:
"-attachment
Adds an attachment to a Teamcenter mail. This argument is required for recipients to
receive Teamcenter mail, but does not have any affect on operating system e-mail."
So, if you are using Teamcenter Mail, then this is ok.  However, if you are using OS mail (outlook etc) then it wont.
Best you can get I think is to use the '-url' argument for OS mail.
Richard Bennett
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Hello Richard,
Thank you for the information.
I will try to use the url argument and see how it goes.
Rushi
Hello Richard,
I tried to use the -url argument but it yields no result.
Attached is the snapshot of the notify task handlers and arguments that I have used.
I have also enabled the EPM_notify_url format preferences.
Am I missing something important or something obvious?
Rushi
Hi Rushi,
I found that you have to set a value for the preference:
WEB_default_site_server
You then get links in your mail.  See attached.
Richard
Richard Bennett
PLM Consultant
It worked! Thank you Richard.
I was wondering if its possible  to get the dataset which is in a workflow to some users Teamcenter mailbox? Can the notify task handle such a request too?
Glad you got it working.
From memory, that's what the attachment argument does? You will have to enable Teamcenter internal mail though if you haven't already.
Richard
Richard Bennett
PLM Consultant
Hello Richard,
I am using the attachment argument, however, I do not get any email in the TC mailbox.
Please see attachment for details.
Rushi
The current settings for mail_server_name is disabled.
As seen below:
You need to enable internal mail...
Have you set the preference Mail_internal_mail_activated?
Richard Bennett
Richard Bennett
PLM Consultant
