How to audit dataset download?
Hi,all!
User can download dataset by using Named References,but we need to record it.
Hiding the Named References menu is not a good choice.
According to the configuration of Audit Manager in BMIDE,we can record File Access logs.However,
i find nothing about dataset download in BMIDE.
How to configure the Audit Manager to record dataset download in Named References ?
Thanks & Regards
Re: How to audit dataset download?
Siemens Genius Siemens Genius
Siemens Genius
I think you can't audit just the downloads (actually, a file read/view involves a download from the server to the client).
My customer (at TC10, audit mode: 3) tracks every file read request (this is a really large number of records) and then exports the collected information to excel files, deleting the exported records from the database.
Paolo
Thank you in advance,Paolo!
Yes,there is no Specific OOTB Audit Definition for logging Download event.
