How to backup BMIDE
Hi guys,
Is is possible to backup all the settings in the BMIDE at some point to go back to it if needed?
I want to back up all the templates at once and then try to load them to another fresh installation if possible.
Cem
Re: How to backup BMIDE
Yes it is possible.
BMIDE ToolBar->Project->Properties-> search for 'Project Backup'.
The Back-up window gives several options like backup-count, location, type etc
TC 9.1
Naveen
How about restoring them?
Is it also as easy as this? Smiley Happy
Cem
Yes it is easy too.
FIle->Import-> Import a BMIDE template project.
I believe your problem is resolved.
project>properties is grayed out?
