How to bulk import scanned pdf to Teamcenter?
Is there anyone who experienced migrating their existing documents (scanned ms office files) to TCRS?
Will this involve writing a program?  What are the steps involved?
Would appreciate your input guys!
Best regards,
Lyka
Re: How to bulk import scanned pdf to Teamcenter?
@Lyka - What version of TC? Are the items already existing in TC that the datasets will be attached to? You will be adding just PDF's, correct?
Jamie
Hi Jamie,
Items are not yet existing. I will start from scratch. From installing TCRS to migrating PDFs.
I am using TCRS 11.2
Lyka
How many PDF's? Because they are not existing, look at TCXML and CSV2TCXML for creating Items and importing Datasets. You can search the forums for CSV2TCXML and find some good posts as well.
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/csv2tcxml-TCXML-data...
Jamie
Search also for "Poor Man's Migration" which uses ps_upload to create Items and Structure, uses import_file to create Dataset and import Named reference, uses Live Excel to populate property values.
