How to change duration to minutes into the Scheduler Manager
I am working on the Scheduler Manager App. I have a bunch of tasks with less than One hour duration and I am unable to set it. The default is that duration is expressed in hours. Eg. 8h.
I also tried using decimals for example with .5 hours but it does not work.
Does anybody knows how to change the duration to minutes?
Salvador
