How to change the Debugging level in Solid Edge
HI,
I would like to change the debugging level in Solid Edge ST6 and to set it to a lower logging level.
After uploading an assembley, the logfiles are showing large number of lines, so I think that the Debugging level is set to be High. So I thought I would change the level to gain performance.
I would appreciate any help.
Thank in Advance!
