How to change the child part's status of BOM structre
I have a question about how to attach specified status to all Item of BOM Structure using workflow.
I am facing problem where when I release the parent item of BOM with WF, only the status of the parent part has release status.
But When I release parent Item on WF, I'd like to attach release status to child items as well.
I dnt't know which handler I should use in this case.
Could you tell me which handler I should use ?
Re: How to change the child part's status of BOM structre
you need to attach items using PS-attach-assembly-components handler (in TC10, but it was EPM-attach-assembly-components prior to release 10) and then use EPM-create-status (create-status prior to TC 10).
