How to clear relation by workflow ?
I need to clear a specify relation in revision by workflow and next create new one. Can create relation but cant clear it. Is there any posibility to do this ?
SE ST9 + TC 10.1.7
Re: How to clear relation by workflow ?
Teamcenter has no COTS action handler to remove/clear a relation by workflow.
You can try EPM-move-attached-objects handler but it is limited to certain relations types as documented.
This requires a simple custom action handler to clear a relation from the workflow attachments
Thanks for reply !
Maybe this can halp but i cant find EPM-move-attached-objects handler in TC client and in help for TC10.1.
Maybe you have different TC version.
SE ST9 + TC 10.1.7
I could see the handler details in TC 10.1.7 documentation but not in any other prior TC 10.1.x versions
https://docs.plm.automation.siemens.com/tdoc/tc/10.1.7/help#uid:xid1256819:index_workflow_designer:i...
Mahendra
We have 10.1.4. In near futer we going to upgrade TC so then I try your suggestion.
SE ST9 + TC 10.1.7
