How to copy value from Occurence property to permanent property?
Hello experts,
customer has a specific question. Is it possible to copy value from occurence property (e.g. Qunatity) to permanent property (e.g. ItemRevision:object_desc) ?
Is it possible OOTB? or we can deliver "custom utility" but better would be OOTB.
thank you.
Re: How to copy value from Occurence property to permanent property?
I can offer you to try the OOTB method, which will require some work from you.
I think you can try the following:
1) Export BOM to Excel
2) Bring the exported Excel file to the form required for the tc_attribute_bulk_update utility
3) Import the values of the required attributes using the tc_attribute_bulk_update utility
https://docs.plm.automation.siemens.com/tdoc/tc/11.6/help/#uid:xid1179066
